ilpeppino79
  • 3Posts
Logitech Harmony Hub with Horizon Mediabox XL
Hi, I wanted to buy the Logitech Harmony Hub to control the Horizon Mediabox xl and other devices (Samsung sound system, dvd player).
Is this hub working fine with the box? Is it worthy to buy it for controlling the TV via Google Home mini?
acoster
  • 1320Posts
  • 56Oplossingen
  • 133Likes
The box is working fine with the hub, only a few commands are not working, as the remote of the box transmits via RF. But also an IR-sensor is build in, but not all commands are working on IR.
Check this forum, there is a list of commands that will not work, but you can program them by making your own 'command'.
https://community.ziggo.nl/randapparatuur-97/logitech-harmony-one-icm-horizon-mediabox-4463
3 Reacties 3
  • 75187Posts
  • 21925Likes
I have nowhere found a message where it is reported that it works well.
Some people report that only a few functions work.
acoster
  • 1320Posts
  • 56Oplossingen
  • 133Likes
ilpeppino79
  • 3Posts
Thanks Acoster! I will give it a try then!
