nmclayton1990
  • 3Posts
  • 3Likes
Viaplay error 404
When I try to activate my viaplay account through subscriptions, a 404 error appears in Viaplay. How can I fix this?
Wim C.
  • 6244Posts
  • 234Oplossingen
  • 4821Likes
Hi @nmclayton1990
Have you already tried it via Mijn Ziggo?
If you go to Mijn Ziggo, you can (if everything works properly) activate a subscription to Viaplay.
If it doesn't work, a Ziggo moderator may be able to help you further.
But a moderator can only help you further if he or she knows who you are. That’s why it’s important that you have your zip code and house number in your profile.
Of course, these address details are only visible to Ziggo employees.
6 Reacties 6
puppie
  • 2637Posts
  • 66Oplossingen
  • 1063Likes
via wat wil je dit activeren? via ziggo of viaply rechtstreeks?
Lycke
  • 14026Posts
  • 1177Oplossingen
  • 6122Likes
Hey @nmclayton1990. Welcome.
It's not entirely clear what you're trying to do. Do you want a viaplay subscription from Ziggo, or from viaplay self?
nmclayton1990
  • 3Posts
  • 3Likes
Hi - I want a viaplay subscription through ziggo.
Wim C.
  • 6244Posts
  • 234Oplossingen
  • 4821Likes
Hi @nmclayton1990
Vincent
  • 4349Posts
  • 574Oplossingen
  • 2124Likes
Hi @nmclayton1990. Did you give @Wim C. his advice a try? Could you provide us an update? Thanks in advance!
nmclayton1990
  • 3Posts
  • 3Likes
Yes this worked! Thanks
