Bodger5
POA-01-B
Hello!
How can I order a POA-01-B device? - I have never been able to fully work my Media Box XL and been too lazy to try and resolve the matter!...but lock-down gives me the time and I read from the number of previous posts about no no connectivity to live services that this is probably due to no return signal.
I also have no a CS9097 fault after Ziggo sent me a new Media Box so now I cannot record programs…..(made me jump into action!)
Thanks in advance and sorry for posting in Engels!
Bodger5
Hi Celia - the POA-01 has arrived and the Media Box works perfectly now 🙂
I stripped out some outdate Astra fittings (splitter and versterker) that were not compatible with a bi-directional signals and fitted a new Hirschman versterker as the house has multiple outputs and voila! - all works fine.
So - this can be closed now please.
4 Reacties 4
anoniemforum
  • 9764Posts
  • 581Oplossingen
  • 2657Likes
a moderator can send you a poa-01-b + modem cable.  just put your zip code and house number in your profile settings
Cecilia
  • 8055Posts
  • 2393Oplossingen
  • 3927Likes
Hi @Bodger5
Welcome to the Ziggo Community.
Posting in English is fine! We would love to help you with resolving this matter. In the meanwhile you already had contact with one of my colleagues and a POA-01 en new cable for you modem has been send. Post NL will deliver it today. Please let us know if this has resolved the issues. If not, please upload photo's of your main connection and connection(s) to your Mediabox XL.
Bodger5
Cecilia
  • 8055Posts
  • 2393Oplossingen
  • 3927Likes
I'm happy to read that everything is working fine again. Thankyou for this update @Bodger5
I will close this topic for you.
