FedericaMaf
  • 6Posts
Mediabox melding oververhitting
Good evening,  my Mediabox TV keeps giving a message that the media box is overheated and then turns itself off. The device is clean and dust-free, but very hot. I've put it on a grid now but that doesn't really help. Your advice please. I received it only 2 weeks ago and until then I am not able to watch the TV.
KBX458
  • 8462Posts
  • 377Oplossingen
  • 2929Likes
Make sure that your ZIP code en housenumber are placed in your community-profile . A moderator will help you further on during workdays (mon - fri)
Folkert
Community Testspecialist
  • 7450Posts
  • 629Oplossingen
  • 3978Likes
Good afternoon @FedericaMaf,
Thanks for joining the Ziggo Community. Your set-top box seems to be faulty and should not display an overheating notification. I have ordered a replacement and this should arrive within 3 workdays via PostNL.
The old and fauly box should be returned. Return information will be included in the package you're about to recieve. If you do have any questions afterwards, please let us know.
8 Reacties 8
KBX458
  • 8462Posts
  • 377Oplossingen
  • 2929Likes
Folkert
  • 7450Posts
  • 629Oplossingen
  • 3978Likes
FedericaMaf
  • 6Posts
Thank you both for your prompt reply and your support!
The new Mediabox is on its way and I hope it will work properly 🙂
Kind Regards,
Fede
stott82
Dear Ziggo, I have exactly the same problem. My Mediabox is >6 years old now, and since a few days ago it overheats regularly. This is causing us big trouble when working from home. Can you send us a replacement please?
Vincent
  • 4349Posts
  • 574Oplossingen
  • 2124Likes
Goodmorning @stott82 and welcome to our Community! Pretty annoying that your box heats up most of the times. Time for some action to replace the box. You will get one as soon as possible. Please keep an eye on your e-mail inbox for the Track & trace code.
stott82
Hi Vincent - that's perfect. I have the track and trace in the meantime. Many thanks!
Riadh_TN
  • 3Posts
Hello,
I am using Ziggo Media box XL for less than 5 months, and recently, it starts displaying the message that the media box is overheated and should be switched off ; There is enough ventilation around the media box; I had to switch off the box for a moment to coll off, and restart again; But the message is becoming more frequent; I appreciat if you customer care can advice.
Thanks
Riadh
Jamyla
  • 5790Posts
  • 685Oplossingen
  • 2411Likes
Hello goodmorning @Riadh_TN
Welcome to our Ziggo Community 🙂
Dissapointing to read you experience some issues with the FAN of the Mediabox XL. We will swap the box for a new one and make sure you receive this within 3 days.
