Tegroeg
  • 8Posts
No internet after moving
Hi!
I have an issue with settimg my modem in my new place. I just moved to Rotterdam, noticed the move to ziggo one week in advance. I just plugged it all yesterday as in the manual, but cant receive any internet. I resetted my box, plugged and unplugged the cables, restarted the whole and still no progress. I managed to login with the ethernet cable and 192.178.... but no change either. My box is still blinking green, and have the green wifi logo. Yet none of my devices can connect. What could be the issue? I cant find any solution so far.  Thanks forward for your help.
16 Reacties 16
tobiastheebe
  • 31066Posts
  • 2181Oplossingen
  • 15502Likes
A technician might be required to (re)connect the cable inside the EV ('eindversterker' or street cabinet).
Could you post one or more pictures of AOP (main socket inside utility closet ('meterkast') or in living room) and cables, plus splitter(s) and signal amplifier, as applicable?
Additionally, could you post the modem’s downstream/upstream data? Instructions can be found here.
Tegroeg
  • 8Posts
 hope that helps!
Tegroeg
  • 8Posts
 there is no data in upstream/downstream
tobiastheebe
  • 31066Posts
  • 2181Oplossingen
  • 15502Likes
Looks like no signal. A technician will most likely have to come over to verify outside connection and install a new AOP.
Could you connect the modem directly to the AOP? The splitter (POA 01-UPC) is redundant.
A moderator (Ziggo employee) can schedule a technician appointment and will visit this topic within 1-2 days.
Could you fill out your address details on this page? These are visible to moderators only.
Tegroeg
  • 8Posts
I have tried to connect the modem directly to the AOP plug, but still same light setting appears on the modem... I have made an appointment with a technician on the 29th, can you notice him of the issue so that he come prepared? Thank you! Hope we can solve that quick, needs internet a lot for my work. Best.
tobiastheebe
  • 31066Posts
  • 2181Oplossingen
  • 15502Likes
I am not employed by Ziggo and cannot provide the technician with additional info. The technician knows what to do after confirming that no signal is present on the AOP.
Tegroeg
  • 8Posts
Dear Tobias,
My mistake. Yet thanks for the help in troubleshooting! Have a good week.
tobiastheebe
  • 31066Posts
  • 2181Oplossingen
  • 15502Likes
No problem, glad to help! Hopefully you will have a working internet connection and WiFi very soon.
Erik P
  • 3232Posts
  • 585Oplossingen
  • 769Likes
Dear @Tegroeg,
Welcome to the Community page! I'm sorry to read the internet/ wifi is not working on your new place.
I see that you've already made an appointment with an engineer. This engineer will help you Tomorrow.
Tegroeg
  • 8Posts
Thanks Erik. I hope internet will work again on the same day! Looking forward to the technician visit. Do you think there would be additionnal costs to the intervention?
Erik P
  • 3232Posts
  • 585Oplossingen
  • 769Likes
Finding a solution is the goal of the technician of course. Because of your movement I don't expect additional costs, unless the technician need to use this material.
Please keep us posted 🙂
Lotte
  • 2761Posts
  • 400Oplossingen
  • 976Likes
@Tegroeg Is the problem solved? I do hope so 😄
Tegroeg
  • 8Posts
Dear Lotte, Erik, Tobias,
Sorry for my late answer! The problem is actually solved on the day the technician came.
The problem was simple, the previous tenant had not Ziggo as internet provider, so my apartment
wasn't linked / cabled to the servor. There was no problem with the modem, as once connected, all was working again!
Thanks for your help!
tobiastheebe
  • 31066Posts
  • 2181Oplossingen
  • 15502Likes
That's exactly what I expected. Glad to read it was as simple as that. Has the technician installed a new AOP (wall socket)?
Tegroeg
  • 8Posts
Yes, correct! You were right, the previous one was an oldy.
The new AOP having only one socket, I am still using the splitter for internet.
tobiastheebe
  • 31066Posts
  • 2181Oplossingen
  • 15502Likes
Could you post a screenshot of the downstream data once again? The splitter is only useful as an attenuator when the signal is too strong, but its second output must then be terminated.
