rayhunter
Ontdekker
  • 5Reacties
Wifi channel keeps changing in manual mode.
Hi,
After selecting channel 120 on 5GHz on my gigabox, after a few days (1 - 7 days), my WiFi channel changes back to either channel 36 or 40.
I have selected manual channel, and have disabled Smart Wifi.
This is quite annoying. Channel 120 is free - no one else nearby uses it. 36 and 40 are quite busy. Can anyone tell me how to stop this from happening?
Ray
Uitgelicht
8 Reacties 8
tobiastheebe
  • 4064Reacties
  • 216Oplossingen
  • 1358Likes
The 5 GHz radio is likely encountering DFS events on channel 120 and therefore switches to a non-DFS channel to comply with regulations. You should be able to verify this using the modem's event log.
rayhunter
Ontdekker
  • 5Reacties
This is very useful, thanks! I'll try another free channel and keep an eye on the logs. I don't seem to have a modem log. The best I have is Tools -> Network Status -> Network Log. I'll keep an eye on that.
tobiastheebe
  • 4064Reacties
  • 216Oplossingen
  • 1358Likes
The 'Network Log' should contain previously occurred DFS events.
rayhunter
Ontdekker
  • 5Reacties
I don't see any mention of DFS or channel changing in the log. Very strange 😕
tobiastheebe
  • 4064Reacties
  • 216Oplossingen
  • 1358Likes
The Connect Box Giga's event log doesn't always display recent events and might actually not display DFS events altogether, contrary to the 'regular' Connect Box.
Could you try the 5 GHz settings below?
  • Channel: 58
  • Channel Width: 20/40/80 MHz
  • Mode: 802.11n/ac
rayhunter
Ontdekker
  • 5Reacties
I have channel 56 and channel 60, but no 58. I switched it to 128 as that channel doesn't seem to be getting used by anyone. I'll try 56 / 60 if 128 also switches back to 36/40.
tobiastheebe
  • 4064Reacties
  • 216Oplossingen
  • 1358Likes
Sounds good, let me know if you experience any subsequent channel switching.
rayhunter
Ontdekker
  • 5Reacties
Ok, thanks for your help!
