awwrohn
  • 16Posts
  • 7Likes
Slow internet speed from wifi - less than 30Mbps with 300Mbps subscription
Since yesterday morning the internet download speed over wifi has decreased significantly. Currently it is between 10-30Mbps while I have the 300Mbps subscription.
I tried via cable and with the cable it is working well and I measured around 290Mbps.
I also turned off and on and after that did a reset on the Connectbox but still the same slow speed via wifi.
Could it be that my Connextbox has some hardware issue again? I had a problem earlier this year and my Connextbox was replaced during the summer, since then the wifi worked well, but since yesterday it has become very slow.
What would you suggest?
  • 66802Posts
  • 4692Oplossingen
  • 18481Likes
Do the 2.4 and 5 GHz have the same name?
It looks like your device is connecting to the 2.4 GHz.
Can you give them different names and then connect to the 5 GHz WiFi transmitter?
2 Reacties 2
  • 66802Posts
  • 4692Oplossingen
  • 18481Likes
awwrohn
  • 16Posts
  • 7Likes
Thank you  @Bert I disabled the 2.4GHz frequency and renamed the 5Ghz one -> now the internet speed is fast again. Thanks for the prompt help!
Polls
Wat is je favoriete seizoen?
