vicente.canhoto
  • 4Posts
Remote Desktop connection drops constantly
Hi,
Since moving to a new house and receiving a new modem, I have not been able to Remote Desktop via VPN to my work office. I also connect to the VPN, and the Remote Desktop also connects, but after a few seconds the Remote Desktop is closed.
Does anybody have any ideas of what I can do? Or do I need a new modem?
Thanks in advance,
Vicente Canhoto
  • 63169Posts
  • 4367Oplossingen
  • 16665Likes
Ik think it is DS-Lite.
IPv4 is shared with 20 others, so there is no IPv4 only for you and the RD stops.
Ask the chat to put your modem in IPv4 only:
The chat box (to be used 24 hours / 365 days per year) appears at the bottom right of the screen of the page below, if someone is available, sometimes wait a while: https://www.ziggo.nl/chat
8 Reacties 8
  • 63169Posts
  • 4367Oplossingen
  • 16665Likes
Possible solution:
Do you see a IPv6 adres under IPv6 connectivity http://ipv6-test.com ?
If there is, aks the chat to put your modem in IPv4 modus.
The chat box (to be used 24 hours a day / 365 days a year) appears at the bottom right of the screen of the page below, if someone is available, sometimes wait:
vicente.canhoto
  • 4Posts
Be rt wrote:
Possible solution:
Thank you for your quick reply!
I don't see any IPv6 address in that test, but a couple of weeks ago I tried the same test (according to some other questions that I read in this forum) and I think I remember seeing an IPv6 address there. I also tried making some changes in the modem settings, and I might have disabled something related to that. When I check those modem settings, I see an IPv6 address. Should I still ask to put the modem in IPv4 modus?
hanh
  • 17054Posts
  • 661Oplossingen
  • 3460Likes
Vincente,
First of all: when http://ipv6-test.com shows no IPv6 address
it just tells you that the system you use for the test did not get a global IPv6 address.
Maybe it should have an IPv6 address, but it was not assigned by the IPv6 Router Firmware for some (strange) reason. As such this is not a real problem. We can look into this, later on.
You write that you see that the Router has an IPv6 address. I presume that you have a ConnectBox. Am I right?
Let's determine what kind of IPv6 Firmware the ConnectBox runs.
I included 2 images, as examples.
Image 1: DS-Lite firmware; CB has only an IPv6 address
Image 2: Dual Stack firmware: CB has both an IPv4 and IPv6 address
What do you see?
Since you can setup a VPN connection to your work office, I don't think that
IPv4 Firmware will solve your problem.
As I understand the Rdp Connection to a host in the Office network over that VPN connection fails in a few seconds, but the VPN Connection does not drop.
Can you confirm this?
Do you use other facilities of your office during a VPN session, like Network disk shares?
Regards Han
vicente.canhoto
  • 4Posts
Hi Han,
Thank you for your help. Yes, I do have a ConnectBox, with DS-firmware, as you can see in the image attached.
Besides the Remote Desktop, I used to be able to open sites with the VPN connection that are only accessible in the office network, but now I tried it and also didn't work.
I can confirm that the VPN connection does not drop. The first time I connect to the Remote Desktop I can actually see my work desktop for a few seconds, until the Remote Desktop connection drops.
Thanks!
Vicente
  • 63169Posts
  • 4367Oplossingen
  • 16665Likes
hanh
  • 17054Posts
  • 661Oplossingen
  • 3460Likes
Hi Vicente,
Thanks for your info. So the VPN Connection as such is not your problem.
Mostly DS-Lite on the ConnectBox gives problems with starting a VPN Connection at all.
It's beyond my imagination why the VPN Connection itself succeeds & holds, but
the use of a service through that connection fails.
I don't think that further investigation makes sense in your case.
I actually don't even know where to start to tackle the problem in an effective way.
So: step over to IPv4 Firmware, like Bert suggests.
This may solve your problem without understanding what's exactly going wrong now. Looked around a bit, but didn't find sources yet that confirm that a good DS-Lite implementation should technically not be able to perform the tasks you need.
So be it.
Please, let us know the result.
Regards, Han
vicente.canhoto
  • 4Posts
After asking Customer Support to switch to IPv4, it worked! Thank you guys for helping.
  • 63169Posts
  • 4367Oplossingen
  • 16665Likes
You're welcome, best regards.
Polls
