Greetings,
I have been a Ziggo internet user for more than 1 year. I am happy with my internet connection other than the router (Connect Box) resets. At first, daily router resets were not a problem since it was able to reconnect to the Internet quickly. However in the last two months it takes longer and longer to reconnect. Even sometimes it is unable to connect until I reboot it to the factory settings.
Last month Ziggo technician visited my house but he just guessed that resets are due to my basic subscription (around 5 Mbps upload speed.) I knew that was not the issue but he just left my house doing nothing.
What I see in my router logs are many of "No Ranging Response received - T3" entries. So looks like same problem with https://community.ziggo.nl/community-archief-226/many-no-ranging-response-received-t3-time-out-errors-and-connection-drops-65898
But root-cause can not be wiring in my apartment because the internet works fine most of the time. And if the router is unable to connect to the Internet for more than 15-20 minutes, a factory reset makes it connect to the Internet again.
I don't want to call a Ziggo technician without a strong proof because it costs 50 euros and doesn't solve anything.
Here are screenshots from Connect Box dashboard;
Do you have any idea to solve my problem?
Best beantwoord door Henno
No.
You are losing probably 3.6 dB in the splitter screwed to the plywood in the cupboard at the building entry and another 1dB in the AOP in your appartment and some 3 dB in the POA-01.
However you could gain 3.6 dB by bypassing the ESX-02 in the building entrance. From the pic the cable that goed upstairs is long enough to make it directly to the AOP there.
