I moved to this flat about 2 months ago and installed gigabit right away. Initially i did not notice these issues. However, as of the last 3 weeks I have constant but random connectivity drops. It is more than a latency spike as i notice the internet not reachable. I also have TP link decos and its easily visible when they go red. Most of the time the connection recovers within a minute, but sometimes a reboot of the router is required. I looked at the downstream/upstream values and suspected my coax cable/wall connection so I made a clean cut on the coax cable and installed a new connector going directly into the router. The values improved but i will attach them as they may be problematic still.
I have to add that other than the disconnects, when testing my connection i always get 900-950 down/48-49 up with <9ms. So majority of the time, everything works as expected. Im having a hard time figuring out why so im reaching out here. Perhaps it is something to do with my area/usage of surrounding neighbourrs.
Best beantwoord door ivandechovsi
Hi, all!
Thanks for the help. Indeed, the problem was with my setup in the cupboard. It was quite old and there were 2 splitters in place. One reduced it by 4 dbmv and the other by another 6! The engineer was surprised i had internet at all.
Anyhow, removing the splitters help a lot. I still have lower power on the high frequency as my modem is not in the cupboard - i do not have power outlet in the cupboard as it sits outside the flat so signal is routed into the flat. Not massive issue but something to improve later on.
Really appreciate the help!
