Shure
  • 67Posts
  • 9Likes
Internet very poor after switching to Giga
My transfer to Giga finally happened over the weekend, but since then I’ve experienced nothing but errors.  In the last 24 hours alone my internet has dropped three times.  Ive been booted out of an Xbox session, in the middle of watching a TV replay I was kicked out and WiFi just drops completely.  I’m now also regularly getting lost signal on my Mediabox Next
My setup is identical to when before I had Giga.  Arris modem/router in the meterkast, with the supplied 1.5m coax cable to the AOP, which was new a couple of years ago.  I have rebooted the Connectbox, but still getting issues.
89 Reacties 89
Shure
  • 67Posts
  • 9Likes
oh, and my download speed is now 12 Mbps
Tom.
  • 5481Posts
  • 205Oplossingen
  • 1222Likes
Could you take a picture of the main connection and what is connected to it?
for most people this could be found in the meter cupboard
Shure
  • 67Posts
  • 9Likes
Thanks for the reply.  The AOP is good and was checked prior to the Giga install 🙂  I can’t upload a picture at the moment unfortunately as it’s so slow even a 2Mb pic is hasn’t uploaded after several minutes 😞
Shure
  • 67Posts
  • 9Likes
trying again
Tom.
  • 5481Posts
  • 205Oplossingen
  • 1222Likes
have you tried resetting your modem to factory settings?
Press and hold the reset button on the back for 15 seconds with a needle or something else.
You mean the wifi goes out on the next?
Or the TV signal?
KBX458
  • 8462Posts
  • 377Oplossingen
  • 2929Likes
A MIMO event is one indicator that the modem restarts.
 I've called in for the help of a moderator.
Shure
  • 67Posts
  • 9Likes
Or the TV signal?
The wifi signal.  I can watch TV, but every so often the red light on the front of the Next light up and I am no longer able to eg watch replays.  The Xbox, soundbar and Sonos also lose wifi connection.  This has only started happening since my internet was upgraded to Giga.  I don’t recall it ever happening before for the past three years but now it’s a multiple daily event
I have rebooted the modem from within the menu but don’t think I’ve reset set back to factory settings, just restarted.  I can try that too, but later as my kids are in the middle of university classes!
Tom.
  • 5481Posts
  • 205Oplossingen
  • 1222Likes
Okay.
Keep us updated?
Shure
  • 67Posts
  • 9Likes
Tom. wrote:
Okay.
Keep us updated?
will do, thanks for your help!
Tom.
  • 5481Posts
  • 205Oplossingen
  • 1222Likes
You're welcome!
Don't forget to thank @KBX458 .
He called in for the help of a moderator?
Shure
  • 67Posts
  • 9Likes
One other thing - it strangely seems to happen only in the evenings.  During the day the connection is relatively stable
Tom.
  • 5481Posts
  • 205Oplossingen
  • 1222Likes
What is the download speed during the day?
http://speedtest.ziggo.nl
Shure
  • 67Posts
  • 9Likes
It fluctuates wildly.  The maximum I’ve gotten is 487 but ten minutes later it can drop to below 100.  Wifi is extremely variable.  Cabled is a little more complicated to assess as I can only do that with a work laptop that has permanent vpn.
Tom.
  • 5481Posts
  • 205Oplossingen
  • 1222Likes
Did you seperate the 2.4 and 5ghz network?
You could do that in your modem by changing the 5ghz network name.
Login on your modem: http://192.168.178.1
Go to geavanceerde instellingen (advanced settings)
Click on draadloos (wireless)
Click on beveiliging (security)
Change your 5ghz network name.
After 10 minutes the 5ghz network becomes visible.
Connect all 5ghz compatible devices to the 5ghz network.
Shure
  • 67Posts
  • 9Likes
stranger and stranger.  I went into the settings and found it’s disabled 2.4Ghz, which was definitely not me.  I’m pretty sure some of my equipment can’t use 5Ghz so this is a bit random
Tom.
  • 5481Posts
  • 205Oplossingen
  • 1222Likes
That is strange…
Can you turn on 2.4 ghz and follow the instructions above?​​​​​
Shure
  • 67Posts
  • 9Likes
Tom. wrote:
That is strange…
yes I’ve now done done both and separated the networks
Tom.
  • 5481Posts
  • 205Oplossingen
  • 1222Likes
Okay you didn't gave them the same name??
Tom.
  • 5481Posts
  • 205Oplossingen
  • 1222Likes
can you do a speed test as soon as you are connected to the 5ghz network?
Share the results here.
