For the last 3 days the internet has been dropping out frequently.
I had a technician visit but he found nothing wrong, the internet was working at the time.
It will sometimes work for a few hours then be either down completely or extremely slow (<1mbs), however the upload speeds will be fine.
Here are the downstream logs from my router.
3.0 Downstream channels
| Channel | Frequency (Hz) | Power (dBmV) | SNR (dB) | Modulation | Channel ID |
| 1 | 602000000 | 7.4 | 40.4 | QAM256 | 1 |
| 31 | 842000000 | 5 | 38.6 | QAM256 | 31 |
| 32 | 850000000 | 4.6 | 39 | QAM256 | 32 |
| 30 | 834000000 | 5 | 38.6 | QAM256 | 30 |
| 26 | 802000000 | 5.7 | 38.6 | QAM256 | 26 |
| 27 | 810000000 | 5.6 | 40.4 | QAM256 | 27 |
| 25 | 794000000 | 5.6 | 40.4 | QAM256 | 25 |
| 29 | 826000000 | 5.3 | 39 | QAM256 | 29 |
| 5 | 634000000 | 6.9 | 40.4 | QAM256 | 5 |
| 17 | 730000000 | 6.1 | 40.4 | QAM256 | 17 |
| 18 | 738000000 | 6.2 | 40.4 | QAM256 | 18 |
| 28 | 818000000 | 5.6 | 38.6 | QAM256 | 28 |
| 6 | 642000000 | 6.9 | 40.4 | QAM256 | 6 |
| 19 | 746000000 | 6.5 | 40.4 | QAM256 | 19 |
| 24 | 786000000 | 5.4 | 40.4 | QAM256 | 24 |
| 3 | 618000000 | 7.3 | 40.4 | QAM256 | 3 |
| 20 | 754000000 | 6.4 | 40.4 | QAM256 | 20 |
| 4 | 626000000 | 7.2 | 40.4 | QAM256 | 4 |
| 7 | 650000000 | 6.5 | 40.4 | QAM256 | 7 |
| 21 | 762000000 | 6.2 | 40.4 | QAM256 | 21 |
| 23 | 778000000 | 5.4 | 40.4 | QAM256 | 23 |
| 22 | 770000000 | 5.9 | 40.4 | QAM256 | 22 |
| 8 | 658000000 | 7 | 40.9 | QAM256 | 8 |
| 10 | 674000000 | 7.1 | 40.4 | QAM256 | 10 |
| 9 | 666000000 | 7.2 | 40.4 | QAM256 | 9 |
| 2 | 610000000 | 7.5 | 40.4 | QAM256 | 2 |
| 11 | 682000000 | 6.6 | 40.4 | QAM256 | 11 |
| 12 | 690000000 | 5.8 | 39 | QAM256 | 12 |
| 13 | 698000000 | 5.5 | 39 | QAM256 | 13 |
| 14 | 706000000 | 5.4 | 39 | QAM256 | 14 |
| 16 | 722000000 | 5.5 | 39 | QAM256 | 16 |
| 15 | 714000000 | 5.6 | 39 | QAM256 | 15 |
| Channel | Lock Status | RxMER (dB) | Pre RS Errors | Post RS Errors |
| 1 | Locked | 40.366287 | 0 | 0 |
| 31 | Locked | 38.605377 | 0 | 0 |
| 32 | Locked | 38.983261 | 0 | 0 |
| 30 | Locked | 38.605377 | 0 | 0 |
| 26 | Locked | 38.605377 | 39 | 0 |
| 27 | Locked | 40.366287 | 81 | 0 |
| 25 | Locked | 40.366287 | 0 | 0 |
| 29 | Locked | 38.983261 | 0 | 0 |
| 17 | Locked | 40.366287 | 0 | 0 |
| 18 | Locked | 40.366287 | 724 | 0 |
| 28 | Locked | 38.605377 | 4 | 0 |
| 6 | Locked | 40.366287 | 0 | 0 |
| 19 | Locked | 40.366287 | 0 | 0 |
| 24 | Locked | 40.366287 | 0 | 0 |
| 3 | Locked | 40.366287 | 0 | 0 |
| 20 | Locked | 40.366287 | 0 | 0 |
| 21 | Locked | 40.366287 | 0 | 0 |
| 23 | Locked | 40.366287 | 0 | 0 |
| 22 | Locked | 40.366287 | 0 | 0 |
| 8 | Locked | 40.946209 | 0 | 0 |
| 10 | Locked | 40.366287 | 0 | 0 |
| 11 | Locked | 40.366287 | 0 | 0 |
| 12 | Locked | 38.983261 | 0 | 0 |
| 13 | Locked | 38.983261 | 0 | 0 |
| 14 | Locked | 38.983261 | 0 | 0 |
| 16 | Locked | 38.983261 | 0 | 0 |
| 15 | Locked | 38.983261 | 0 | 0 |
3.1 Downstream channels
| Channel | Channel Width (MHz) | FFT Type | Number of Active Subcarriers | Modulation (Active Profile) | First Active Subcarrier (Hz) |
| 33 | 96 | 4K | 1860 | QAM2048 | 879 |
| Channel ID | Lock Status | RxMER Data (dB) | PLC Power (dBmV) | Correcteds (Active Profile) | Uncorrectables (Active Profile) |
| 33 | Locked | 39 | 1.4 | 103970 | 0 |
