Zijn mijn internetwaardes goed?
  • 30 juli 2020
  • 15 reacties
  • 231 keer bekeken
Reputatie 1
1 52000000 44 5.120 64qam 1
2 58800000 44 5.120 64qam 4
3 36000000 43 5.120 64qam 3
4 44500000 43 5.120 64qam 2
Gebundelde upstream-kanalen
1 2.0 0 0 53 0
2 2.0 0 0 14 0
3 2.0 0 0 8 0
4 2.0 0 0 16 0
1 274000000 3 38 256qam 1
2 282000000 2 38 256qam 2
3 290000000 3 38 256qam 3
4 298000000 3 38 256qam 4
5 306000000 3 38 256qam 5
6 314000000 3 38 256qam 6
7 322000000 3 38 256qam 7
8 330000000 3 38 256qam 8
9 338000000 3 38 256qam 9
10 346000000 3 38 256qam 10
11 354000000 3 37 256qam 11
12 362000000 3 38 256qam 12
13 370000000 3 37 256qam 13
14 378000000 3 37 256qam 14
15 386000000 3 37 256qam 15
16 394000000 2 38 256qam 16
17 402000000 3 37 256qam 17
18 410000000 3 37 256qam 18
19 418000000 2 37 256qam 19
20 426000000 2 37 256qam 20
21 434000000 2 37 256qam 21
22 442000000 2 37 256qam 22
23 450000000 2 37 256qam 23
24 458000000 3 37 256qam 24
Gebundelde downstream-kanalen
Kanaal Locked Status RxMER (dB)  Pre RS Errors Post RS Errors
1 Goed (Locked) 38.605 142514576983 117147
2 Goed (Locked) 38.605 142470141975 117067
3 Goed (Locked) 38.605 142470140552 115504
4 Goed (Locked) 38.605 142470135060 118456
5 Goed (Locked) 38.605 142470141336 109456
6 Goed (Locked) 38.605 142470103312 107071
7 Goed (Locked) 38.983 142470099789 106753
8 Goed (Locked) 38.605 142470093668 110274
9 Goed (Locked) 38.983 142470079817 119975
10 Goed (Locked) 38.605 142470091511 112158
11 Goed (Locked) 37.636 142470082595 113499
12 Goed (Locked) 38.605 142470081094 111907
13 Goed (Locked) 37.636 142470071619 117510
14 Goed (Locked) 37.636 142470062506 123624
15 Goed (Locked) 37.636 142470061389 122640
16 Goed (Locked) 38.258 142470055184 123488
17 Goed (Locked) 37.636 142470049841 124273
18 Goed (Locked) 37.636 142470031926 127236
19 Goed (Locked) 37.636 142470034433 126387
20 Goed (Locked) 37.636 142470225979 125888
21 Goed (Locked) 37.636 142470222223 128242
22 Goed (Locked) 37.636 142470218659 127639
23 Goed (Locked) 37.356 142470213429 130193
24 Goed (Locked) 37.636 142470126129 126478
wat zien jullie ?
Best beantwoord door anoniemforum 30 juli 2020, 17:55
en ik heb dit gesodemieter sinds ik de mediabox xl in het netwerk heb hangen.
het het is niet aan te raden je mediabox xl te verbinden met je modem door een bug in de mediabox xl blijft de DHCP actief waardoor je twee DHCP server heb met als resultaat een haperende verbinden
het advies is dan ook de kabel uit je mediabox xl te halen
indien de mediabox xl verbonden is via wifi die wifi verbinding verbreken
15 Reacties
Badge +8
@griebel
Graag ook foto's daar van hoe je modem op het AOP aangesloten zit.
Reputatie 1
Badge +8
@griebel Het modem zit aangesloten op OUT 1?
De waardes zijn goed maar wel redelijk wat post RS fouten, wat is de beschikbaarheid van het modem (staat onder beheer)?
Kun je de netwerk historie log en de upstream ook nog posten??
Heb je verder nog klachten?
Reputatie 1
Netwerk historie
Tijd Prioriteit Omschrijving
30-07-2020 16:37:19 notice GUI Login Status - Login Sucess from LAN interface; client ip=[192.168.178.108];CM-MAC=90:5c:44:c2:14:e8;CMTS-MAC=00:01:5c:b1:30:49;CM-QOS=1.1;CM-VER=3.0;
30-07-2020 16:36:34 notice Illegal - Dropped FORWARD packet: SRC=2a03:2880:f045:0012:face:b00c:0000:0002 MAC=01:5C:B1:30:46:86;CM-MAC=90:5c:44:c2:14:e8;CMTS-MAC=00:01:5c:b1:30:49;CM-QOS=1.1;CM-VER=3.0;
30-07-2020 12:05:13 notice GUI Login Status - Login Sucess from LAN interface; client ip=[192.168.178.108];CM-MAC=90:5c:44:c2:14:e8;CMTS-MAC=00:01:5c:b1:30:49;CM-QOS=1.1;CM-VER=3.0;
30-07-2020 12:04:43 notice Illegal - Dropped INPUT packet: SRC=125.138.57.18 MAC=00:01:5C:B1:30:46;CM-MAC=90:5c:44:c2:14:e8;CMTS-MAC=00:01:5c:b1:30:49;CM-QOS=1.1;CM-VER=3.0;
30-07-2020 11:50:51 notice GUI Login Status - Login Sucess from LAN interface; client ip=[192.168.178.108];CM-MAC=90:5c:44:c2:14:e8;CMTS-MAC=00:01:5c:b1:30:49;CM-QOS=1.1;CM-VER=3.0;
30-07-2020 11:48:19 notice Illegal - Dropped INPUT packet: SRC=172.217.17.134 MAC=00:01:5C:B1:30:46;CM-MAC=90:5c:44:c2:14:e8;CMTS-MAC=00:01:5c:b1:30:49;CM-QOS=1.1;CM-VER=3.0;
29-07-2020 16:52:08 error
DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=90:5c:44:c2:14:e8;CMTS-MAC=00:01:5c:b1:30:49;CM-QOS=1.1;CM-VER=3.0;
Reputatie 1
1 2.0 0 0 53 0
2 2.0 0 0 14 0
3 2.0 0 0 8 0
4 2.0 0 0 16 0
Reputatie 1
of ik verder klachten heb ?
zo’n twintig keer per avond wegvallen verbinding met kijken naar ziggogo.tv op iMac
en bij kijken naar netflix geen probleem.
ik wordt er een beetje moe van.
mvg
Reputatie 1
modem op out 1
Reputatie 1
Badge +12
Badge +8
@griebel de post van @anoniemforum  is zeker om naar te kijken; de mediabox XL heeft ook een DHCP server en 2 stuks daarvan op hetzelfde netwerk is chaos.
Hey @griebel .
Dit geeft een heel erg duidelijke oorzaak, zoals hierboven al gezegd wordt. Heb je je modem inmiddels uit het netwerk weten te halen? Zo nee, dan raad ik aan dit zo snel mogelijk alsnog te doen! (check hier hoe)  Laat je ons weten hoe het hierna gaat? :-)
Reputatie 1
1 2.0 0 0 0 0
2 2.0 0 0 0 0
3 2.0 0 0 1 0
4 2.0 0 0 1 0
kijk zo ziet er nu uit, geen last meer van uitvallen.
ik ben blij.
maar ik hoop dat ziggo bij het verzenden van de mediabox er een notitie bij doet dat ze dat apparaat niet in het netwerk moeten hangen.
dat had het mij vele maanden ellende gescheeld.
maar bedankt voor deze goede tip.
Reputatie 1
bedankt voor de goede tip
mvg griebel
@griebel  Ontzettend fijn om te lezen dat het met de tips die hier gegeven zijn opgelost is! Als je nog andere vragen hebt, kun je hier altijd weer terecht. Jou feedback m.b.t. de installatie zal ik doorgeven.
Nog een fijne dag gewenst!
Groeten,
Paul
Reputatie 1
:yum::ok_hand_tone3:
