Onze internetverbinding is al heel lang behoorlijk traag. Onlangs toch maar eens een (bekabelde) speedtest gedaan. Toen bleek dat we de in het abonnement beloofde downloadsnelheid van 250 Mb inderdaad bij lange na niet halen. We komen met moeite aan de 71 Mb. Ik vermoed dat ons oude Cisco EPC3925-modem de boosdoener is. De up- en downstreamwaardes lijken namelijk in orde:
Downstream Channels
Channel 1:
Channel ID: 1
Downstream Frequency: 602000000 Hz
Modulation: 256 QAM
Power Level: -2.9 dBmV
Signal to Noise Ratio: 40.8 dB
MER: 40.8 dB
Correctable FEC: 25115 codewords
Uncorrectable FEC: 469 codewords
Microreflections: 12 dBc
Channel 2:
Channel ID: 2
Downstream Frequency: 610000000 Hz
Modulation: 256 QAM
Power Level: -2.8 dBmV
Signal to Noise Ratio: 41.2 dB
MER: 41.4 dB
Correctable FEC: 17356 codewords
Uncorrectable FEC: 210 codewords
Microreflections: 31 dBc
Channel 3:
Channel ID: 3
Downstream Frequency: 618000000 Hz
Modulation: 256 QAM
Power Level: -3.1 dBmV
Signal to Noise Ratio: 40.9 dB
MER: 40.9 dB
Correctable FEC: 18437 codewords
Uncorrectable FEC: 322 codewords
Microreflections: 34 dBc
Channel 4:
Channel ID: 4
Downstream Frequency: 626000000 Hz
Modulation: 256 QAM
Power Level: -3.2 dBmV
MER: 40.8 dB
Correctable FEC: 33348 codewords
Uncorrectable FEC: 568 codewords
Microreflections: 11 dBc
Channel 5:
Channel ID: 5
Downstream Frequency: 634000000 Hz
Modulation: 256 QAM
Power Level: -2.6 dBmV
Signal to Noise Ratio: 40.7 dB
MER: 40.8 dB
Correctable FEC: 41050 codewords
Uncorrectable FEC: 700 codewords
Microreflections: 13 dBc
Channel 6:
Channel ID: 6
Downstream Frequency: 642000000 Hz
Modulation: 256 QAM
Signal to Noise Ratio: 41.0 dB
MER: 41.1 dB
Correctable FEC: 40212 codewords
Uncorrectable FEC: 1007 codewords
Microreflections: 28 dBc
Channel 7:
Channel ID: 7
Downstream Frequency: 650000000 Hz
Modulation: 256 QAM
Power Level: -3.3 dBmV
MER: 40.8 dB
Correctable FEC: 49231 codewords
Uncorrectable FEC: 1313 codewords
Microreflections: 35 dBc
Channel 8:
Channel ID: 8
Downstream Frequency: 658000000 Hz
Modulation: 256 QAM
Power Level: -3.6 dBmV
Signal to Noise Ratio: 40.4 dB
MER: 40.5 dB
Correctable FEC: 83063 codewords
Uncorrectable FEC: 2123 codewords
Upstream Channels
Channel1:
Channel ID: 3
Upstream Frequency: 36000000 Hz
Modulation: 64 QAM
Bit Rate: 30720 kBits/sec
Power Level: 45.0 dBmV
Channel2:
Channel ID: 1
Upstream Frequency: 52000000 Hz
Modulation: 64 QAM
Power Level: 46.7 dBmV
Channel3:
Channel ID: 2
Upstream Frequency: 44500000 Hz
Modulation: 64 QAM
Power Level: 45.2 dBmV
Channel4:
Channel ID: 4
Upstream Frequency: 58800000 Hz
Modulation: 64 QAM
Power Level: 47.0 dBmV
Statistics
T3Timeouts: 0 timeouts
T4Timeouts: 0 timeouts
Ligt het aan ons modem of zou er nog iets anders aan de hand kunnen zijn?
Best beantwoord door Rikst Ziggo
Hi
Welkom hier op de Community! Ik snap dat je graag je verbinding weer op peil wilt brengen nu deze al een tijd traag is!
Zowel het modem als de splitter zijn wel aan vernieuwing toe, ik zorg dat je die toegestuurd krijgt. Je ontvangt per e-mail de Track&Trace zodra deze bekend is. Na het aansluiten ben ik natuurlijk benieuwd hoe het gaat! Het Cisco modem hoeven we niet retour, deze mag je inleveren bij de milieustraat.
