The connectbox configuration options do not have the port forwarding and DMZ options on the GUI. Is it no longer possible to do port forwarding or enable DMZ on connectbox?
Best beantwoord door tobiastheebe
It looks like your modem has received an IPv6 DS-Lite configuration profile. If you need the port forwarding and DMZ features, you must contact the helpdesk to have them re-provision the modem for IPv4.
